DIY: Build your own positive battery cable 9456836 for the 850
This topic is in the MVS Volvo Repair Database » Fabricate a Positive Battery Cable DIY
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Jason, great DIY! Scheduled for inclusion in the repair database.
Also -> Amazon link
ThommyKent
Year and Model: 91 245 97 850 T5
Been thanked: 5 times
Post by ThommyKent »
matthew1 wrote:Jason, great DIY! Scheduled for inclusion in the repair database.
Except it is not done correctly
matthew1
Site Admin
Post by matthew1 »
My VRD entries always point back here to the forum, to the original post. So people will read this very thread and will know about the soldering no-no.
Also -> Amazon link
ThommyKent
Thanks, good to hear!
Has thanked: 1613 times
Been thanked: 4075 times
From my boating life...
West Marine stores have a public crimper that they will let anyone use to crimp wires and swages.
Just tell them for its for your boat, and leave off the Volvo adjective .
Google west marine store locator to find the nearest one.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Thanks for the feedback! I don't know if the soldered connection will have better reliability than the crimped connections. I promise to field test mine and let everybody know as soon as it shows signs of failure.
SpeedyPete
Year and Model: S70-T5, 1998
Post by SpeedyPete »
Hello all out in Volvo land :P The idea that you can make a die and use a bench vice to crimp an electrical lug to proper torque pressure is flawed. To do it correctly one needs to use the proper tool. Our small lug compression tool reaches 12-15 tons and our large tool is in the 22 ton range. Note the different color stripes on the lugs. This is to identify which matching die to use in the tool to the lug being crimped. Best Wishes to all, SpeedyPete 8)
matthew1
Site Admin
Post by matthew1 »
My positive cable let go entirely two days ago. I didn't know how far gone it was, and when I was working on fixing the battery to the tray (non-stock size battery, that's a whole 'nother story), the cable gave out.
So to get the car running as a temporary fix, I took off a bit of the end of the cable's sheath and screw clamped it to the terminal clamp.
It's ugly but it works. It's temporary until I can get the parts for this DIY.
Also -> Amazon link
jreed
Post by jreed »
Ingenious! I'm curious to see more pictures of your method!
You can get perfectly good electrical connection, long term with stripping and bolting battery cables vs swaged or compression lugs. They WILL need more maintenance and inspection for corrosion and correct tension but cars came this way for a long time. We crimp 100 amp marine connectors using rigging tools in the salt water environment where corrosion is much worse.
