1991 240 Transmission not engaging any gear.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
yosef7
Year and Model: 240 92, 740 91
Post by yosef7 »
My 91 240 automatic transmission stopped working yesterday. Engine runs and revs fine. It was slow in shifting gears the day before but nothing to suggest a total failure. Yesterday, I backed up. went forward and drove aprox 6 miles city to hwy and the transmission was no longer engaged while driving. Pulled over and called for a tow. After checking fluid levels and color/smell. (Both fine) I thought, give it a try. It worked for about another mile or two. I waited again and again it worked, for another mile. Limped it back home this way. Any ideas of what I should look at today.? Great vehicle other wise. 250k on the vehicle. yosef
May you always have enough.
yosef7
Post by yosef7 »
Changed fluid. Helped for short trip. fluid gets hot and no movement. Any ideas on rebuilding, replacing, or I will have to sell.
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
Is it leaking out somewhere? when was the last time you changed the tranny filter. sometimes they leak at the spedo cable going into the tranny. mine is doing it now. I just add a tab of ATF daily until I can fix the leak, but it shifts fine.
Maybe it's time for a rebuild? how many miles on it? junkyard have em for cheap if you decide to buy another tranny. just don't crush it!!! :shock:
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
yosef7
Post by yosef7 »
Thanks. I just changed the fluid the week this started. no leaks. I think it is time for a rebuild. Seals must not be holding when fluid gets hot and thin.
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
When you are checking the autobox fluid level you are doing it with the engine running, if not the dipstick won't read the level correctly - Mike
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
yosef7 wrote:Thanks. I just changed the fluid the week this started. no leaks. I think it is time for a rebuild. Seals must not be holding when fluid gets hot and thin.
Did this problem start before or after changing the fluid?
1988 Volvo 760 Turbo Wagon
