2000 v70 xc Torque specifications bolts
doug549
Year and Model: v70 2000
Post by doug549 »
Looking all over for a list of bolt specifications. 2000 v70 xc awd se 2.4 turbo 20 valve
Has thanked: 292 times
Been thanked: 765 times
The Haynes manual is your best source if you want a long list of torque specs, though it is not ideal for a 2000.
People can probably look up specific bolts for you though, let us know.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
doug549
Post by doug549 »
Replacing timing belt, water pump and crank and cam seals due to oil leaks. All of the information I have read on this forum pointed to replacing the stopped up crankcase ventilation system. Awesome site. I would need torque specs. for crankshaft, intake and exhaust(variable timing) cam pulley bolts. Thanks in advance.
