1998 S70GLT what besides Propane to detect vacuum leaks?
jose456891
Year and Model: 850 GLT 2.4 1996
Re: 1998 S70GLT what besides Propane to detect vacuum leak
Post by jose456891 »
So did someone do a recent PCV job on your son's car?
macs70GLT
Year and Model: S70 GLT 1998
Post by macs70GLT »
No we haven't done the PCV.
Not sure why the intake manifold would spring a leak like this. We've had the car 2 years; from 147K to 170K miles.
I have done normal routine maintenance, it's had the water pump replaced within the last year and I did the timing belt last August.
But nothing that would upset the intake.
Planning to replace the intake gasket, and injector seals within the next week.
Lars: 1988 245, 250K mi retired
Son of Lars: 1998 S70 GLT, 225K mi retired
Beast Mode: 1995 940T, 213K mi
Son's car: 1998 V70 GLT, 182K mi
Hans: 2002 Audi A4 QMT, 142K mi
Has thanked: 292 times
Been thanked: 765 times
Since the intake manifold has to come off, this would be a very opportune time to service the PCV. I'd give it a look, at least pull the oil trap to ream out the block passage and replace the short hoses from the trap to the block. Replace the two long lines with bulk hose and you're good to go.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1497 times
Been thanked: 3809 times
You can do better with a 1/4 inch Tygon tube as a stethoscope for finding noises/ vacuum leaks.
I've taught my teens to isolate the noisy part under the hood using this. Latest victim has been power steering pump on Admirals BMW
Reason: Mike Tyson complained about using his name, corrected to Tygon
rmmagow
Year and Model: V70 1998
Post by rmmagow »
what's a Tyson tube?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jose456891
Cut-up garden hose???
rmmagow wrote:what's a Tyson tube?
It's used on the Porsche boxer engine...
Please read Tygon tube instead. Your flexibility is appreciated
