Hello there,
Can the ECU tell when the oil is low, possibly with a oil pressure sensor, and try to stop the car from running?
I wondered about this because i had a stalling issue recently and found that the oil was down by almost a quart.
I did not get an oil light or any trouble light or trouble code though.
Any ideas if this would stop the car from running?
Thanks.
Can the ECU detect low oil 1998 v70 ?
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- Has thanked: 2199 times
Not that I have ever heard of. Best warning is the oil pressure warning light just before your engine goes 'Boom'!
There are many things that can cause stalling from old cracked hoses, MAF failing, fuel issues, on -98 cars the ignition coil failing, cam or crank position sensors to name a few. If you have recently been fishing around the distributor and airbox area, it is possible to move the cam position sensor cable too close to the distributor. That then interrupts the signal for the cam sensor and kills the engine. I had that issue many years ago with a 93 850 after a dealer visit. They diagnosed the cam sensor, I diagnosed the wire issue. My fix was cheaper!
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
My wife drove our 95 10V to the point where the oil light came on. It was low by almost 2 quarts. The rod knock vanished, and the motor runs to this date.
What's the point of this story: The oil light comes on 2 liters low, so I think your stalling issue has nothing to do with the oil.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Being a quart low is not gonna cause a stall.
If it did, you’d have much bigger problems.
Any Check Engine Light? OBD ll codes?
Regarding whether or not the sensor and
warning light are tied into the ECU, have
you downloaded the manual of schematics?
It should be clearly indicated there.
Volvo Technical Publication TP 3932202
- MrAl
That's very interesting. I was wondering, can i change the cam and crank sensors myself?scot850 wrote: 10 Nov 2022, 09:53 Not that I have ever heard of. Best warning is the oil pressure warning light just before your engine goes 'Boom'!
- MrAl
Hi,BEJinFbk wrote: 10 Nov 2022, 11:50 Being a quart low is not gonna cause a stall.
Thank you. I had suspected that but with this car i never know what they did with it.
No check engine light, no OBDII codes, and no pending OBDII codes.
I used to have some schematics but not sure what i did with them. I'll try to find that publication thanks.
Yes you can change both yourself. Cam sensor was quoted at 1 hr at the dealer, I think it took my about 10 mins. Crank is a bit more involved, but again do-able. Not re-programming. Fit and play. With the cam sensor wire, just make it is routed as far away from the distributor as possible. I would try that first before spending any money.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 113 times
If you have some good 1/4" extensions the crank sensor isn't too bad of a job, you could probably get both done in an hour
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- MrAl
Thanks Neil.scot850 wrote: 10 Nov 2022, 22:43 Yes you can change both yourself. Cam sensor was quoted at 1 hr at the dealer, I think it took my about 10 mins. Crank is a bit more involved, but again do-able. Not re-programming. Fit and play. With the cam sensor wire, just make it is routed as far away from the distributor as possible. I would try that first before spending any money.
Are these two hard to find on the car? I guess under the hood somewhere right?
Here is a link to Our good friend Robert's video on crank sensor:
Here is the cam position sensor swap from Pelican parts:
https://www.pelicanparts.com/techarticl ... esting.htm
Apologies, it was the crank position sensor that was the issue on my 850, not the cam position sensor!
- 691 Views
Last post by xc70dude
- 16 Replies
- 4342 Views
Last post by ZionXIX
- 11 Replies
- 3108 Views
Last post by tryingbe
- 4382 Views
Last post by Clemens
- 2408 Views
Last post by shaker_chi
