98 S70 T5 So why did the check engine light not go off?
rmmagow
Year and Model: V70 1998
Re: 98 S70 T5 So why did the check engine light not go off?
Post by rmmagow »
I'd have her go to Volvo for a code pull. Lurking tranny problems would be something to get in front of pretty quickly I'd guess. She should ask them to write down on the invoice all the codes discovered. They'd be in that "E" format right, the one where the code is pretty accurately described?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Has thanked: 292 times
Been thanked: 765 times
Typical causes of p0108 are MAF, IAC and the MAP (actually I think it is a baro sensor). If changing the MAF cleared it up then maybe the problem was indeed the MAF.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Been thanked: 468 times
Post by cn90 »
MAF code is P0103:
http://www.obd-codes.com/p0103
MAP code is P0108:
http://www.obd-codes.com/p0108
There might be something in common between P0103 and P0108, but I am not aware of this fact.
SpeedyPete
Year and Model: S70-T5, 1998
Post by SpeedyPete »
So here is the plan of attack: 1- Check Tranny Fluid for level,color,smell,feel. All good 2- Check codes Replace MAP Sensor and clear codes. My daughter can handle this. Hopefully the CEL and codes will comply. Then :D and drive all is good !!! If not take it to the shop for a full diagnostic. Thank you all in Volvo Land, I will let you know how this turns out.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
SpeedyPete
Thank You RSPI ! This will help my daughter for sure!
rspi
Post by rspi »
I have made several video's for my daughter. ;)
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
rspi wrote:Just the direction I figured you would go. Driving 50 miles with a CEL with NO CODE will cause a lot of trouble? This is exactly why I had you on my blocked/ignore list for about 60 days. I guess I will reactivate that feature. Sail on...
You guys should race for Pinks to settle your differences!
.......Monica!!!!
.......VTEC just kicked in yo!
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
rmmagow
Post by rmmagow »
I like that! Race for Pinks, that's how we did it back in 1962, pinks and beers (and no ga dang seat belts you fairy!) :-)
Has thanked: 1502 times
Been thanked: 3817 times
Mod note - deleted/edited a couple of posts from people who had been working on their volvos too much.
Play nice in the sandbox of emptied EVAP charcoal canisters please.
