965 Overextended door... sigh
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
sanfelice
Year and Model: 00 VR;04 XC70;97 965
Post by sanfelice »
I have done this before with worse consequences, but...
the door on my 1996 wagon was ajar and I put the car in neutral to slide down my drive a bit. well, the door caught the edge of some railroad tie and jammed. not too bad, but about 90 degrees to the car, definitely too far.
apparently, the uppermost hinge has bent back from the body panel, leaving a few mm gap. now, the door still closes and it seems in fine horizontal line, but there is a gap at the handle, where it meets the rear door.
what are my options for adjustment?
and, how would i remove that upper hinge to correct the problem for good?
thanks
JDS60R
Been thanked: 3 times
Post by JDS60R »
Best to remove the door and fix the pillar and hings so things line up. If lucky the hinge is bent and can be replaced. ( Salvage ones are cheap) .
Retired
JDS60R
Post by JDS60R »
The "A" pillar would have received the bend if the hinge did not fail.
Here are some guides to help.
If not handy - body shops do this all the time.
965 door compnenets.pdf
(117.57 KiB) Downloaded 182 times
965 door hinge front.pdf
(38.42 KiB) Downloaded 87 times
965 door pad compnent removal.pdf
(129.05 KiB) Downloaded 94 times
Retired
sanfelice
Post by sanfelice »
thanks a bunch.
however, any schematic for removing the hinge from the body side? i know how to remove the door itself, it's quite easy, but the body side hinge is bolted from somewhere in the bowels of the upper dash/windshield area.
thanks.
sanfelice
Post by sanfelice »
ah, ok, I see, they say "remove A-post side panel"
i will try that.
