965 - removing AC clutch *only* not compressor?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
sanfelice
Year and Model: 00 VR;04 XC70;97 965
Post by sanfelice »
My clutch blades seem to have broken (rusted) off, so I need to replace it, but research on the FAQ shows it requires a special tool.
Any links or pics to which tool?
would this kit contain the tool?
http://www.tooltopia.com/cps-products-ctk1300a.aspx?utm_source=shopzilla&utm_medium=cse&utm_campaign=sc&scpid=24&scid=scsho6810598
Ethan Rode
Year and Model: 960 1996
Post by Ethan Rode »
That is the tool. depending on your ability, you may be able to make your own tool. You'll probably need to remove the compressor from it's mount, and work on it from underneath the car, after you've removed the center nut. Make sure you are gentle with the two giant A/C hoses, they are big money to replace!
Removing the pulley from a Sanden compressor (similar to yours)
http://youtu.be/R6RGgFTpzWY
A/C Clutch Repair
http://youtu.be/j7yflp1WFrU
