Make double sure the large, hinged, hooded connector is well seated. The hood needs catch the pins on the connector portion on the module itself to draw the connector down in place securely.
Do it yourself ABS module repair. Topic is solved
Do It Yourself ABS Module Repair
- Year and Model: Many Volvos
- Been thanked: 76 times
- Been thanked: 4068 times
I think I would give Matty Moo a call, especially if you are in Ontario and can cross the border into MI easily!
Ozark Lee wrote:Make double sure the large, hinged, hooded connector is well seated. The hood needs catch the pins on the connector portion on the module itself to draw the connector down in place securely.
thanks. I will go check it right now.
abscate wrote:I think I would give Matty Moo a call, especially if you are in Ontario and can cross the border into MI easily!
who is matty moo? yes, i am in hamilton ontario.
Midwest ABS sell replacement ABS modules tested and guaranteed.
I'm a happy customer myself
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
Large harness looks fine, just make sure it's seated down all the way.
Something to remember, your car is now 18 years old so you may have another issue outside of the module.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Thanks for this tut. I did this today on my dads 1998 v70, as the light had been on since the previous owner had it. I just reflowed and added some solder to the two power supply joints, fitted it back in and after driving about 50m, the light vanished. It took me about 3 hours to crack open the box though, I did it as neat as possible.
