Time spent pulling manual transmission?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
Anyone have an idea how long it would take an average shadetree mechanic like me to pull a manual transmission + components?
- pedal assembly
- two control cables, and the shifter assembly that replaces the auto shifter
- master cylinder, slave cylinder, and pressure line.
- clutch assembly
Also -> Amazon link
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
what equipment have you got?
how much light, space, &c?
is it a junkyard car? ie, do you care to keep the whole car in perfect shape or can you take some creative shortcuts?
i's got no idea how long it should take but i'd guess the answers to these questions are going to have a major impact on the time it takes to do the job
matthew1
Site Admin
Post by matthew1 »
It's a local part out car, on it's way to the crusher. I'd have my AC impact wrench and hand tools. I'd bring my floor jack, ramps and stands.
No idea on space, light etc.
Also -> Amazon link
JDS60R
Been thanked: 3 times
Post by JDS60R »
Issue will be with the trans removal. If no lift, then you will need to jack it up and lower subframe. Once you have the subframe lowered figure 1.5 hrs to pull the trans and clutch and 2 hours for the pedal, cables, switches, ecm,tcm etc. ( That's at full speed)
With no idea of whats available for equipment I would bring, the jacks, stands and tools, at least 1 friend and dedicate 7 hours to it. You could be out in 3-4hrs but I would show up early, bring coffee for all and pack a lunch. This way at closing time you will have it.
Retired
matthew1
Site Admin
Post by matthew1 »
Ok that gives me a good idea of time. Thanks you two.
Also -> Amazon link
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
I pulled everything else I need in less than 4 hours, in a junkyard, with no jack and not caring about the car.
85 GLH, 367 whp
00 Insight, 72 mpg
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Do I smell another M56 swap on MVS coming?
