Hello all. New to the site. Have a question about an egr issue. CEL light on p0420. Cleaned egr and replaced vacuum lines. Still getting p0420 code after approx 3 drive cycles. Car does have a aftermarket MAF. If it weren't for required emissions I would let it ride. Any ideas? Any way to test the egr controller?
Thanks in advance
1996 850 EGR p0402 any fixes ?
jetmecanic
- Year and Model: 1996 850
JDS60R
- Been thanked: 3 times
P0420 is a catalyst efficiency code. Usually related to a failed cat from lack of maintenance on replacing A/F ratio sensors ( Oxygen sensors, MAF and coolant temp sensor). Search the database here and you will find tons. If I remember your model does not like aftermarket MAF sensors.
Hit the cat from below and see if it is broken up, if not get a temp reading on the front weld bead and the rear. The rear should be 300 degrees F higher if the catalyst is functioning on a warmed up car.
Please refer to forum rules on using All caps or Help in title. You agreed not to when signing up.
Retired
jetmecanic
JDS60R
My bad. Wont happen again. Made a typo on the title. The code is p0402 not p0420.
jetmecanic
Quick thanks and update. Replaced all vacumn hoses and all checked good. Thanks all!!!
- Has thanked: 2650 times
- Been thanked: 1240 times
Thanks for the followup.
- 3606 Views
- 4406 Views
Last post by MadeInJapan
