An all of a sudden breakdown landed me in a transmission shop with this current diagnosis:
Needs transmission rebuild, likely problem is the oil pump or torque converter.
Shop's quote is $3185 with 2 years or 24,000 miles warranty.
The car has 155k on it. I'm the second owner and I have all the repair records. Although the shop says that the car's engine sounds good and typically this Volvo will easily go to 200k, is this repair a wise investment?
And if you are familiar with this car, what other major repairs may come up in the next 2 years or near 170k?
I've appreciated this site's information and advice in the past, but have never posted on the forum. Any advice would be greatly appreciated. Thank you.
1999 S70 - Transmission Needs Rebuild
mynamemongo
- Year and Model: 1999 S70
- Has thanked: 1506 times
- Been thanked: 3819 times
You should look at a good used one from a pick and pull or broker.
I guessing 1/2 that price in total ?
I see parts listed at 500-700 usd with 6 month warranty, for reference
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
In my neck of the woods you can likely replace the entire vehicle for that. Whether it is worth fixing depends on what kind of shape the car is in generally, whether you have kept up with the maintenance along the way, and what your budget for a vehicle is.
Things that can/do need attention around that age/mileage in no particular order (and most would be considered regular maintenance):
PCV service;
Suspension rebuild
possible exhaust replacement
front axles
tires
motor mounts
starter
radiator
heater core
seat covers (leather)
coolant reservoir
engine coolant temperature sensor & thermostat
front door check straps (mostly driver door)
both oxygen sensors if not previously replaced with OEM (Denso)
brake rotors/pads/ebrake along the way.
(All this is for a non-turbo, non awd vehicle -- I do not know what additional repair items/expense you might face for turbo and AWD)
Those are just a few that come to mind. Bear in mind if you are uncertain of the maintenance history, have neglected oil changes and used cheap regular gas, you may be set up for a burned exhaust valve around 200K miles.
If I were inclined to keep that car, I'd find an independent shop and have them swap in a known good used unit for probably around $2k including parts.
If you have the space, I'd consider saving your current vehicle as a parts car and obtaining an exact replacement used as far as model specification goes -- that way, you have handy spares available.
PCV service;
Suspension rebuild
front axles
tires
motor mounts
starter
radiator
heater core
coolant reservoir
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
At this age, it is also a good idea to replace all cooling system hoses (with OE quality hoses or better) as preventive maintenance. Nothing will kill these engines faster than a severe overheat. Pretending 15 year old hoses still have their original integrity is false economy.
'95 855 auto (sold)
'95 855 auto (sold)
- instarx
- Year and Model: XC70 T6 2011
Used transmissions at my local yard are $600 - $800 depending on mileage. It should not cost $2,500 to put it in so you can save a lot going to what used to be called the junk yard.abscate wrote:You should look at a good used one from a pick and pull or broker.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
mynamemongo
I use the car currently as my one and only car. At this rate, no more than 2 more years.chexny wrote:everything said above eshowell. Plus what are you using the car for? How long do you plan on keeping it.
tryingbe
- Year and Model: None
- Been thanked: 26 times
If you are not able to do the work yourself, I would dump the car and find another working one.
You can buy a working 850/S70 for less than 3k or other cars.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
wheelsup
- Year and Model:
- Has thanked: 15 times
- Been thanked: 20 times
OP your situation is exactly what prompted me to go out and just outright buy another 850 with a bad motor but good transmission. I bought the whole car for $250, then sold the hulk of it after stripping everything I wanted off of it for $130, making it cost $120 for the thing. I got a transmission as well as tons of relays, sensors, new Valeo radiator, etc. Awesome deal.
I had called around and shops were quoting around $2700 or so in NC for the rebuilt AW50-42LE transmission. It's unfortunate it costs so much for those things, because a lot of otherwise good cars end up sent to the scrapper because of it.
If you ever have an inkling to do it yourself, and you have a garage and a basic set of tools, it's totally do-able by one person in 2-3 days time if you don't want to spend the $3k on the car (I personally draw the line at around $1k, anything more and I'll just put it toward a newer car).
https://www.matthewsvolvosite.com/forums ... =1&t=53437
1995 850 GLT Wagon w/ 200,000 miles
- 746 Views
Last post by didjeridave
- 640 Views
Last post by InsertPunnyName
