98 S70 Problems removing axle from hub
kevins s70
- Year and Model: 2007 XC70
I am in the process of replacing a steering rack, struts, and axles. i am however having real issues getting the front passenger side axle out of a hub. The boots were shot on the axle for quite a while and i have a new axle as part of the project. At this point i have removed the axle from the car with the hub still attached. The axle absolutely refuses to budge from the hub. So far i have tried lots of pentetrating oil and a 10 pounder - nothing. Also tried a jaw gear puller and no luck. Any suggestions?? I think the axle has been in there for maybe 8 years.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
Autozone offers this tool on loan http://www.autozone.com/autozone/accessories/OEM-2-Ton-2-or-3-jaw-puller/_/N-264g?itemIdentifier=2044_0_0_
- Year and Model: Many Volvos
- Been thanked: 75 times
I've never had a problem getting the axle out of the hub. I think I would be inclined to put the nut back on the axle and smacking it laterally to see if it pops free. You can't really use a torch without screwing the hub itself up.
- Been thanked: 472 times
The splines may have metal adhesive from factory.
Spray WD-40, PB Blaster etc.
You may want to use just a touch of heat (propane torch) to melt the metal adhesive from factory. The problem is: don't use too much heat because the wheel bearing is nearby. You don't want to damage the bearing.
xHeart
OP is a first timer, as I was oncecn90 wrote: ...
It will likely damage bearing by proximity.
Some people put the axle nut back on, flushed with the end of the axle, then whack with a hammer.
Since the hub has been removed from the car, you will have to find a way to secure it before whacking it the nut.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
And use a proper hammer, 3~5 lb short handled sledge hammer, not a carpenter's hammer. I don't know if they still make lead sledges, but those work great, the kind you'd use on an english car with a single center wheel nut.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
I say no heat but use that Autozone puller pictured in the earlier post, tension it as much as possible, and then you can use a relatively small hammer (like 1 pound) to break the spline loose.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
kevins s70
Thanks everyone for your suggestions. After another struggle and soaking it all day in pentetrating oil it is apart! The axle i am quite sure is original and if Volvo did use an adhesive of some sort it was overkill. The way i finally got it off is as follows. I used a jaw gear puller but that in itself was not enough. Using the jaw puller i would only get maybe a quarter turn and it would stop dead. I then used a 3lb hammer
and hit the jaw puller bolt a couple of times which seemed to loosen up the axle. Did my next quarter turn hit the jaw puller bolt again. I had to do this until the axle was almost out. Also really important is that the jaw puller bolt be well greased - can't emphasis that more. I am thinking to use a light coating of antiseize on the axle spline when i put it back together. Any thoughts on that? Thanks again for all the suggestions.
- Has thanked: 292 times
- Been thanked: 765 times
Anti-seize on the splines at the hub when installing the axle: absolutely!
If you can, be sure to save your original Volvo axles. They can be rebuilt, the aftermarket ones can not and frequently fail quickly.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 2178 Views
Last post by [email protected]
- 1150 Views
Last post by j-dawg
