1999 Volvo V70 XTC DTC codes P1133, P1174
thepetercasey
- Year and Model: 1999 V70 XTC
car starts and runs, the idle appears to 'bounce', i.e. the RPM's are erratic when cold, it bounces between 500 to 1100 RPM's. After some driving, the problem goes away. If you shut off and restart the car, the problem returns. Fuel consumption has increased. Any help would be appreciated
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Welcome to the forum,
Those two codes combined with poor performance and low fuel efficiency are indicative of HO2S going bad.
BTW, How many miles on the clock? (The oxygen sensors usually deteriorate after 100K.)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
thepetercasey
currently the vehicle has 130k miles. I just tried cleaning the MAF sensor. The problem remains, thanks
- regent
The other part of the story is that code 1174 is an indication you are running lean (air to fuel ratio is too high), which leads to higher combustion temperatures with consequences. It is a good idea to check for vacuum leaks around the TB and intake before replacing the upstream HO2S.
Cheers!
Cheers!
2015 BMW 335i
2015 BMW 335i
thepetercasey
thanks & Cheers
