98 s70 no start intermittently.MVSOLVED, dirty IAC
AVIP
Year and Model: 98 s70
Re: 98 s70 no start intermittently
Post by AVIP »
Took that guy off and got some new clamps at napa. Couldnt see past the valve. So used a whole can on it and got it all cleaned up. Idles wayyy lower and drives a lot better. Fixed my stalling! Simple fix. Costs me 1.29 lol
98 Volvo S70 NA 198K - SOLD
02 Volvo S80 T6 150k
AVIP
Post by AVIP »
Thank you for all your help. Would have never thought of that
Has thanked: 1505 times
Been thanked: 3818 times
Nice. Don't forget to tithe some portion of the 4 hours of labour at 110 USD per hour you saved to MVS....a shameless plug but not beneath me ...
You still might have an ignition switch problem, which is a 15 minute, 50 USd fix.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
This reminds me, I've been meaning to ask. My idle is very steady but it seems high to me at about 950rpm. I don't have anything other than the stock tach to estimate, does anybody know what the factory idle should be?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Been thanked: 472 times
Post by cn90 »
On the same topic, after a PCV job, I attached the LOWER hose to the ICV but forgot to tighten the clamp!
Somewhere on the road, the engine stalled, restarted, stalled etc.
Long story short, the LOWER hose came loose! Tightened the clamp, all is good.
I think the ICV should be part of routine maintenance, i.e., every 40K-50K, take it out and clean. It is basically free, it costs you nothing (well, the cost of carb cleaner and that is it).
AVIP
Post by AVIP »
Mine idles now around 800-850 with ac on
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
mecheng wrote:...My idle is very steady but it seems high to me at about 950rpm...does anybody know what the factory idle should be?
For n/a it seems normal.I bought my car almost new,back in 2000,with 69k km and idle speed was always 900-950rpm with ac off.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
@ mecheng ...
I missed the fact that you have a t5.
They have lower idle than n/a models,around 800-850rpm with ac off.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
AVIP
Post by AVIP »
And... I spoke too soon.
Here is exactly what happened. Drove 15 min to work. About 88 out. Got in a space and shut it off. And I wanted to put it back on so I restarted it and the car tried but didnt turn over and stalled. Then it would barley turn at all until I nailed the pedal and it started and the idle down was horrible it jumped 900 to 800 rpm in a second. Wasnt a smooth movement.
I am starting to suspect the crank position sensor
mecheng
Post by mecheng »
misha wrote:@ mecheng ...
Is there a specification listed somewhere, I'm definetly above 850 rpm.
