Just replaced the PCV system on my S60, as well as dropping and cleaning the oil pan/sump. Thing still smokes like a fogger truck.
I had the turbo off, and it spun free and didn't look too bad (can't see that much). Some of the banjo bolts were clogged with oil/sludge. Cleaned what I could.
Question is... Next step. Should I rebuild the turbo? My thought is that there is a blown seal in the turbo that is passing oil to places it shouldn't be.
2008 s60 still smoking
jimmy57
- Been thanked: 320 times
Have yu driven it enough to clear catlayst of oil?
Check the hose that goes to rhrottle for signs of oil, you may have oil in the intercooler from the past problem that is still being blown into intake.
Yes, you could have stuck seal rings in turbo but perfect bushings nad no axial or radial play.
Big shout out to GPop. Turbo cleaned and rebuilt. There are cheaper kits out there on eBay, but I don't know the quality and the service from these guys is great. Called several times with questions and they walked me through it.
After an initial burnoff, the smoke seems to have stopped. Fingers crossed.
- Has thanked: 1506 times
- Been thanked: 3820 times
Don't forget to call them out in the Good mechanics Forum!!!!
- 30 Replies
- 8321 Views
Last post by Ben850
- 11 Replies
- 2250 Views
Last post by gordo850turbo
