2010 XC70 Jacking Points and Brake job
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
aisrael
Year and Model: 1993 244 1995 854
Post by aisrael »
I have to replace all the brakes on my mother's 2010 XC70. I figured I can use the stock jacking points to lift one wheel at a time but I would like to put the car on stands to do this job.
Where are all the jacking pinots on this car so i can lift the entire rear or the entire front and place the car on stands.
Aaron
aisrael
Post by aisrael »
Also, what are the torque specs for the caliper mounting bolts for the fron and rear calipers?
Aaron
Has thanked: 1503 times
Been thanked: 3817 times
Aaron - Ill look up the specs on my 1999 - they might be different than the 2010 of course, but Ill confess to not even using a torque wrench on these when I do brakes - I tighten by experience.
For my 1999....
Install the locating pins (2) in the brake caliper
Check the rubber sleeves of the locating pins. Replace if necessary.
Lubricate the locating pins using grease, P/N 1161325-4.
Insert the locating pins into the rubber sleeves. The pins should slide into the sleeves easily.
Tighten the locating pins. Tighten to 30 Nm . Install the protective caps and the securing spring (3).
Tighten the brake hose in the caliper. Tighten to 18 Nm
30Nm is about 22ftlbs torque, so 40 pounds of force on a 6 inch ratchet handle. This isn't rocket surgery so get them tight and they will stay.
