1999 S70r poor running MVSolved - bad ground
b2fkb0
Year and Model: V70r,855r,s70t5m,xc
Has thanked: 5 times
Been thanked: 4 times
Post by b2fkb0 »
Well, last week I was prepping for Carlyle. Just finished adding the k24 and a custom rip. Image
She was looking good! Took her out on a 10 minute drive and the turbo oil feed line burst, causing total oil loss...in a mile I lost all my oil before realizing something was wrong. My motor seized...
The small hose I used to make my feed line failed. Boy was I ticked after hours of work! But I should've known better; oh well there's that 01 t5a at the local Lkq...
Last Saturday we went and grabbed it!
After 5 hours to pull it, 2 more to clean it I had the new heart ready!
After another 10 hours the new motor is prepped (new tbelt etc and rms), the stuck motor is ready to be pulled!
I missed Carlisle this year but hopefully I'll be able to swing it next year!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
Holy smokes! Catastrophic engine failure!
Sorry about your loss, but you're obviously good enough with engine pulling/prepping to get a new motor installed. Glad the job is in good hands. I wish I could be there to learn/help/document this transplant.
Questions: the small hose, were the clamps not tight enough? What was your first indication of failure? Loss of power? Or sound? Or oil light?
Also -> Amazon link
b2fkb0
Post by b2fkb0 »
Hi Matt
I flared the steel line on both ends and then used quality clamps. The hose I used burst in the middle
My own darn fault as I grabbed the best piece of hose I had (marine grade fuel hose). It wasn't heat rated. I had little to no warning; the engine lost power and I saw a cloud behind me looked down and the dash oil light was lit, my pillar gage was at zero, as I went to turn the key off there was a little squeak and that was that. I lost all the oil in less than a mile in about a minute. You're welcome anytime! There's plenty of room and my wife is a good cook!
Bluevanacd2005
Year and Model: 1983 760
Post by Bluevanacd2005 »
I wouldn't had thought to use a rubber hose for that part. On the turbo mods I've done I have stuck with all metal line and compression fittings on the pressure side. Rubber for the return line though.
Spenser
I like curves on my women, not my cars
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Fuel hose, fuel injection hose, vacuum hose, silicone hose, oil cooler hose, coolant hose, etc, are all specific to the application they called for.
Sorry you have to find out the hard way.
85 GLH, 367 whp
00 Insight, 72 mpg
Bluevanacd2005
I just go to AZ and get some 3/8" brake line and some brass compression fittings. Only tools you would need are standard wrenches, tubing bender and tubing cutter. This was on a Isuzu diesel.... I don't know if the lines were american or just close enough to allow the fitting to tighten onto it. That's the only issue I could for see though- metric/odd sized lines.
Spenser
b2fkb0
Post by b2fkb0 »
Yep I solved it for the new motor; all steel stock s60r line. The 01 motor accepts this line without modification! Every hour I reflect on this project that there is no skimping or quick fixes...
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I feel for you, after doing all that work I would be so pissed. You have a patient wife to allow you to spend so many hours on your car
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
instarx
Year and Model: XC70 T6 2011
Post by instarx »
I have garage envy. I used to have a house with a detached two-car garage, but I moved. Do I ever miss it!
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
b2fkb0
Post by b2fkb0 »
I'm lucky that my wife understands my hobby! I built this garage; I appreciate the positive comments. My son and I put the new engine in last night and I'm buttoning her back up! Road ready pretty soon...
