98 V70 Wheel Toe Settings
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I wrecked a pair of tires on my car due to toe setting problems. I had a 4-wheel alignment done on a different set of good tires and all is fine. Now I am replacing the two tires I ruined, 205/45 17's and putting them back on the car. Is there any particular reason I should have toe checked again with the new tires. The current tires are wearing fine and have been on at least for 6000 miles since toe was adjusted. Basic question, if alignment is in good shape does it change when changing to different wheels. current tires are 15 inch snows on steelies, summer tires are on Volvo alloy wheels.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
If the offset is different yes. If the car is not pulling and steering is straight let it go. For your own edification however take a measurement. Park your car on level ground, as much as possible. Find the same spot about the same height on the front and rear treads and take a measure. If they are within 1/16 of an inch you are in good shape. The preference is Toe-In meaning a smaller measurement in the front of the tire rather than the back. Much easier with a helping hand.
rmmagow
Thanks BKM. Tires go on today and I'll get my wife to help with a quick measurement.
