Hi,
I changed my ETM this weekend & inspected the PCV system, while the PCV looked good & must have had recent service from the po, the charge air piping was somewhat oily inside.
So the question is how much oil is normal inside the ducts & what could be it's source other than pcv, how prone are the turbos to leak oil into the piping?
Thx, Ben
'01 XC oil in air ducts, pcv good
Master Chief
- Year and Model: V70 2002
Seems likely that the seal in the turbo is leaking
- Has thanked: 1502 times
- Been thanked: 3817 times
I would say an oil film in the induction pipe would be normal. If you have liquid oil in the tubes, turbo seal leak or heavy PCV blowby indicated.
- 10 Replies
- 1659 Views
Last post by lummert
- 16 Replies
- 2350 Views
Last post by wizechatmgr
