1999 S70r poor running MVSolved - bad ground
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
Re: 99 S70r motor stuck!
Is it the stc or SRS light?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
b2fkb0
- Year and Model: V70r,855r,s70t5m,xc
- Has thanked: 5 times
- Been thanked: 4 times
Stc and the ets lit. I have an srs lit as well but that's been on for a while. The tach jumps to 1500 on start up but then goes to zero after 10 seconds. I cleaned the ground wire very well and tested the voltage through it and it appears to be good. I'm thinking of inspecting my etm wire for possible problems. I put new loom covers on those wires that had crumbling going on; maybe I did something during that install. What sensor(s) drives the tach signal on a 99? Thanks!
Dan
Dan
- Has thanked: 2655 times
- Been thanked: 1248 times
Outstanding! What a sweet ride. That engine is CLEAN. Great work, b2.
b2fkb0
Thanks Matt! Yeah it was a diamond in the rough with only 126k. The body was clean (no damage) but the tranny had burnt fluid. That was why it was in the yard. I like a clean engine bay so I put some work on it before dropping it in. Sure nice to drive it again!
Dan
Dan
