2009 XC70 T6 AWD - Whining Noise from TCV @ Unlock
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
rod850
Year and Model: XC70 T6 - 2009
Post by rod850 »
So I finally got my wife into a Volvo!!!
We brought home a used 2009 XC70 T6 AWD a couple of days ago.
I went down to the garage last night to put in an ice scraper for her and noticed a whining noise coming from the general vicinity of the vacuum pump when I unlocked the car (engine is not running). The noise stopped after a couple of minutes but I want to make sure that nothing is wrong or if something is, I know what to tell the dealership to look at.
The only repair they did before putting it on the lot was to replace the vacuum pump so my main concern is that something is wrong with the install or the part or something related that should have also been replaced.
Any help would do a lot to ease my mind that my prego wife isn't driving a ticking time bomb.
This video shows what is going on:
Thanks!
rod850
Post by rod850 »
bump
VCA
Year and Model: 2008 S80 T6 AWD
Been thanked: 5 times
Post by VCA »
That's a normal sound. My 2008 S80 makes this sound, as does a 2010 V70 that I've driven. The vacuum pump is engine-driven, so it's not that (they tend to leak oil, mine was changed a year ago for that). In the vicinity of where you videoed is the ABS pump (which I believe does a self test when the car is powered up), and I believe this to be the source of the noise, though I haven't investigated it thoroughly since it's a sound I've heard on two cars on the same platform. Happy motoring!
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Turbo control valve is cycled when the network comes up and ECM is active. Normal noise.
VCA
Post by VCA »
jimmy57 wrote:Turbo control valve is cycled when the network comes up and ECM is active. Normal noise.
Ah-ha! I forgot the common denominator! Both cars I heard it in were T6s...didn't even think of the turbo's electrically-activated bypass valve, because, of course, it was vacuum-actuated on the S/V/C70 family...
2008 S80 T6 AWD
1999 S70 GLT
rod850
Post by rod850 »
So it sounds like the noise is from the TCV.
Is it always that loud?
This post says that around 60k they start to go:
https://www.matthewsvolvosite.com/forums ... =1&t=48871
Our car is @ 63k so does the noise get louder as they start to go?
Sorry for all the questions just want to make sure the dealership knows of any problems ASAP.
Thanks
VCA
Post by VCA »
The TCV is a different part # than the older cars, I would expect the newer part to be longer wearing (Volvo has a good record of fixing the weak spots in later iterations of their cars). My S80 has 82k on the clock with no signs of it going bad, while the friend's V70 has, I think, around 160k on it.
2008 S80 T6 AWD
1999 S70 GLT
jimmy57
Post by jimmy57 »
I was referring to the tcv and yes they are loud enough to hear if you listen or if car is in quiet area. If it has been disturbed by repairs or service then it will louder than it used to be. Pull engine cover and with it buzzing see if the noise level changes if you move it.
rod850
Post by rod850 »
Well I went down last night to look under the engine cover and the noise is barely noticeable.
I've been telling my wife to let the car idle for a minute or two after she starts it and before she turns it off so the oil can circulate to the turbo, I don't know if that has made the difference or if maybe the weather warming up a bit did something, but the noise is exponentially quieter.
I'm going to keep my ear on it, but I'm thinking I can move my attentions else where.
Thanks for all the input.
Has thanked: 1498 times
Been thanked: 3810 times
You can get better compliance if you mark off 30 seconds from home and ask SWMBO to coast down from there into the driveway with revs under 2000 rpm.
No one likes to sit in the driveway, unless you bring her a martini first.
