1998 C70 T5 - No upshift when L gear is engaged/Idle dipping
andreborges
- Year and Model: C70 T-5 1998
Re: 1998 C70 T5 - No upshift when L gear is engaged/Idle dip
There did not seem to be a leak in neither hoses. I looked in the back again for some leakage and there was none. What a mistery this car is... :S
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
Check the Idle air control valve? Maybe It is just that.
Why did you use a 3.5/4 bar FPR? The original ones are 3bar. If it supplies a higher pressure maybe that is causing some problems (leaking Injectors for example?).
850 T5-R '95 auto
andreborges
Danke, hausmeister, for the info. It was the only one with matching aperture to the needed, and as you suggested, I will replace it as soon as money allows (I'm a student!! lol:().
I have one final question, though: is it correct that, even after all I replaced, I'm getting 12mpg-5km/l in city driving? That's been the main reason I've been resigning of driving it everyday, as it deserves...
hausmeister
andreborges
You have a point, as it is really possible that it is interfering with my injectors. I know the fuel pump can provide some 5 bar before reaching its full capacity. Thanks, hausmeister.
Maybe you or some other conaisseur can help with the abhorrent mpg my car is producing?
hausmeister
Is it running well otherwise? Do you get full performance/boost?
Engine Temperature is ok (thermostat)?
850 T5-R '95 auto
andreborges
Sorry it took me so long, hausmeister. I replaced the 4 bar with a new 3 bar.
Sometimes, when flooring it, it seems a bit tired. Most of the time there is plenty of power. The only concern has been the random coughing while idling and the tiny dip, as soon as I've stopped.
It has, for a month now, been consistently pulling at 20l/100km. There MUST BE something wrong, though I cannot figure out what!
- 3160 Views
Last post by 00VolvoS70NonTurbo
- 35 Replies
- 4446 Views
Last post by precopster
