2001 S40 Code PO133 Help!!!!
1996 - 2004 S40
1996 - 2004 V40
nelschri
Year and Model:
Post by nelschri »
I have a PO 133 code (O2 sensor slow intake) coming up on my car. I have already changed the O2 sensor (before the Catalyic converter), the spark plugs, the thermostate, and the fuel filter. My car is taking a while to start 2-4 seconds and is chugging when having to climb a hill or accelerate. Does anyone have any idea's? Is this happening to anyone else? Any help or suggestions would be appreciated.
Chris
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Sounds like a vacuum hose leak, an intake hose leak or a MAF sensor going out. Check all of those things. Also double check that you replaced the 02 sensor with the right one.
aconcha
Year and Model:
Post by aconcha »
Hello.
Did you figure what is going on?
I have the same problem. I replaced oxygen sensors. (direct fit ones!)
I haven't change thermostast. Do you know how this may generate the problem?
By the way, ussually when the MAF sensor is not working you can not start
the engine.
Thanks.
nelschri
Year and Model:
Post by nelschri »
I have checked all the vacume hoses and have had no luck. My car is taking a longer time to start then usual so my next move is to check the MAF sensor. If you have any luck with anything please let me know.
Chris
