To remove my radiator, I unbolted the sas pump, so it's just dangling at this point. After the cooling system update, the exhaust manifold replacement will be next. This would be the time to delete that system if I'm going to do it.
Suggestions?
96 855 na SAS pump, remove or leave?
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I pulled mine out.
When in doubt, pull it out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- Has thanked: 294 times
- Been thanked: 767 times
I always get rid of it as soon as it is convenient to do so.
Here are a few other opinions: https://www.matthewsvolvosite.com/forums ... 3&start=14
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Oh, if you already have the diode, then the pump comes out for sure. The same day usually!
I meant, I do the whole process as soon as convenient, install the diode plus remove all of the hardware.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
JimBee
- Has thanked: 25 times
- Been thanked: 42 times
So, on the 850 na with SAS, the diode goes between a32 and a37? I haven't opened up the module yet, are pin numbers indicated on the board or do I just need to count them to know which to solder?
Yes, A32 and A37. There are numbers on the pins outside but they are really hard for me to see. I don't know if they are on the board too. The VS writeup is very clear on this job.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1511 times
- Been thanked: 3829 times
If it's running sweet, you must delete.Matty Moo wrote:I pulled mine out.
When it says "no mas", remove SAS
