96 855 na SAS pump, remove or leave?
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
To remove my radiator, I unbolted the sas pump, so it's just dangling at this point. After the cooling system update, the exhaust manifold replacement will be next. This would be the time to delete that system if I'm going to do it.
Suggestions?
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I pulled mine out.
When in doubt, pull it out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Has thanked: 294 times
Been thanked: 767 times
Post by erikv11 »
I always get rid of it as soon as it is convenient to do so.
Here are a few other opinions: https://www.matthewsvolvosite.com/forums ... 3&start=14
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Year and Model: 2004 V70 2.5T
Been thanked: 476 times
Post by cn90 »
I am thinking about getting rid of it too. Extra weight for nothing b/c I already did the diode SAS delete.
Post by erikv11 »
Oh, if you already have the diode, then the pump comes out for sure. The same day usually!
I meant, I do the whole process as soon as convenient, install the diode plus remove all of the hardware.
'06 S60 R, 197k
JimBee
Post by JimBee »
So, on the 850 na with SAS, the diode goes between a32 and a37? I haven't opened up the module yet, are pin numbers indicated on the board or do I just need to count them to know which to solder?
Post by erikv11 »
Yes, A32 and A37. There are numbers on the pins outside but they are really hard for me to see. I don't know if they are on the board too. The VS writeup is very clear on this job.
'06 S60 R, 197k
Has thanked: 1511 times
Been thanked: 3829 times
Matty Moo wrote:I pulled mine out.
If it's running sweet, you must delete.
When it says "no mas", remove SAS
