2001 xc wagon AC stop blowing cold air after a few minutes
jb1882
Year and Model: xc wagon 2004
Post by jb1882 »
Hi all.
A year or so ago my AC stopped working properly.
It began like this. It would stop blowing cold air when the car was at a stop light idling.
But only then. I would turn it off for a few minutes and turn it back on and it would be fine as long as the car was moving.
But now stops blowing cold air after a few minutes. I turn it off for about 10 minutes and back on to get cold air for a few more minutes.
I have been researching possible problems or fixes but have not come across my symptoms yet.
Do these symptoms point to something specific?
Thanks
J
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Your symptoms are those of excessive a/c compressor clutch gap.
"clutch gap" will get you a lot of information if you search.
If you get a good flashlight and drive your car until it stops cooling you will be able to see the center for the a/c clutch stopped if it is this problem.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Have you recharged AC a year ago?
bobbieandrick
Year and Model: XC 70 2003
Post by bobbieandrick »
vtl wrote:Have you recharged AC a year ago?
I have a 2003 XC70 and it is doing the same thing. The AC works fine as long as you are not in traffic. When it turns off you have to turn it off and wait about 2 minutes and then turn it back on. Has anyone found a solution?
jb1882
Post by jb1882 »
No, I have never had the AC recharged in the 6 years I have had the car.
I will look into the other issue mentioned.
Thanks
J
jb1882
Post by jb1882 »
jimmy57 wrote:Your symptoms are those of excessive a/c compressor clutch gap.
Ok. Just read this article.
https://www.matthewsvolvosite.com/downlo ... AC-Fix.pdf
Does sound like it could be the problem.
We will try to check it out tomorrow or so.
Is it an easy enough fix for someone who has never done it?
Has thanked: 1500 times
Been thanked: 3812 times
The shim fix isn't too bad but takes a couple of hours working on your back.
95% of us here, myself included,fix this with the bread clip fix of either plastic shims, zip ties, or metal shims inserted on the clutch side. This takes about 11 minutes.
