2000 v70 non turbo What Spark plugs to get?
fathrington
Year and Model: 2000 v70
Post by fathrington »
my volvo book says bosch fr7dc or champion r9yc. is that true or should i look into volvo plugs like some people suggest? this is a non turbo 2000
Has thanked: 1500 times
Been thanked: 3810 times
Non turbo is less critical, either plug is fine. Some claim iridium Plugs give better mileage with payback for higher cost but I've never seen data, only anecdotes.
Been thanked: 466 times
Post by cn90 »
Turbo or non-turbo, it does not matter re plug choice.
I have copper Bosch ($2/each) in my 1998 S70 GLT, runs fine but every 20K or so, you need to re-gap it.
In my 2005 XC90 2.5T, I put in NGK BKR6EIX ($7/each), runs very smoothly, no hiccups whatsoever.
Over the long run, the Iridium wins because for $25 difference ($5 x 5 plugs = $25), the Iridium can maintain the proper gap much longer than copper.
I will not go back to copper, I am an Iridium convert...
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Hmm don't know whether it matters on a non turbo whether they're correct or not. The factory fits these when new and I replace them usually with OEM or the NGK equivalent 3 prong spark plugs. Image
Post by cn90 »
Mike,
Switch to NGK Iridium, you will never look back to Copper.
I just got 50,000 kms from a set of OEMs but they might as well have been quality NGKs. Cost is only 1/2 of Iridiums and I don't really like leaving plugs in too long as the threads need to be relieved and re-lubricated with anti-seize every couple of years anyway.
Nothing worse than stripped head threads :D
