97 850 loctite color on throttle plate
camjohns
Year and Model: N/A 850 97, 850R 96
Has thanked: 6 times
Post by camjohns »
Getting ready to do the throttle plate on my 850, as i took everything apart to clean it. What color loctite should i put when putting the throttle body back together? i have seen some post that say red, while others say blue
thanks!
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Use blue loctite if you plan on taking it apart again in the future; red is pretty hard to break loose without applying lots of heat.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
dosbricks
Post by dosbricks »
Blue like regent said. And I don't know, this may only be me--but I only use it on the uppermost threads of the bolt near the shank or head. That way if there is any kind of problem loosening it in the future, there are still good threads deeper in the hole. If this is a bad practice, someone who is more informed please correct me.
camjohns
Post by camjohns »
This sounds great! do you think a hair dryer will get hot enough to loosen the bolt or will i have to try something else?
thanks!
regent
Post by regent »
If you already have red loctite in there, the hairdryer method is a joke. If not, then try a drop ot two of some penetrating oil like PB or Liquid Wrenck but be careful not do get it on the TP Sensor or wiring. Give it some time to work.
2015 BMW 335i
camjohns
Post by camjohns »
got it out after letting it soak with some PB.
thanks for all the help!
regent
Post by regent »
Yep, glad you sorted it ...despite my typos...
Liquid Wrench NOT Wrenck :oops:
2015 BMW 335i
