1999 XC70 I broke the clip that attaches to fuel filter
Dougernautt
Year and Model: 1999 V70XC AWD
Post by Dougernautt »
After the PB blaster worked I was so excited I jumped under the car and removed the driver side hose first then the the other was a bit sticky. Anyways it cracked and here is the picture. I think the is between fuel pump and filter side....Any body ever have this issue ? Thanks in advance.
Dougernautt
EDIT* sorry I meant connector ring. Can I buy just that ring ? The other side turns within the hose so I assume it comes out.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Hose assembly. If it has any slack, you may be able to attach what is left with a clamp.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Yeah, you broke the fuel line clean off.
I wedge a 14mm wrench between the filter and the fitting and pry the fitting off. Works like a charm!
Been thanked: 466 times
Post by cn90 »
Get standard fuel hose 8mm diameter type.
Cut old hose back a bit.
Cut new hose to appropriate length.
Connect them together using a brass coupler (hardware store) and clamps.
