2000, S70, GLT - Intermittent Stumble/Possible Misfire
Rbaratt
Year and Model: 850,S70,C70
Re: 2000, S70, GLT - Intermittent Stumble/Possible Misfire
Post by Rbaratt »
Yes, the new coil pack is installed and has solved the misfire issue. Thanks for the update on the ETM. I think that when I need the ETM serviced, an Xemodex rebuild will be the way to go. Nice to hear that you have had good luck with your rebuild. Did you have any issues accessing the ETM? Is it fairly easy to remove?
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
Reinie
Year and Model: 1999 S70
Post by Reinie »
Very easy. Most difficult was un-coupling the wire harness. Mine didn't have a retainer clip, just needed to pull hard.
