97 855R Just bought it and I love it..except a few issues
Re: 97 855R Just bought it and I love it..except a few issue
Just to be safe I will be doing a full rear brake job this weekend. Anyone have any experience with Mobil 1 0w-40 with these R engines?
1997 855R-Completely Bone Stock..for now
Finally resolved the brake issue!!!!! So happy. So it turns out the rear rotors were 'pitted' and needed replacing as well as some loose and rusted caliper clips. The car had been sitting for quite some time so it pretty much needed a rear brake refresh. Now the car stops stronger and smoother than ever. Thanks to everyone for their advice and comments. Learned a lot already. Only minor problem I am facing now is the fact that the e-brake functionality is completely non existent after having the shop do my rear brakes. I will be going back tomorrow.
The 02 sensor code has been cleared as well and hasn't come back yet after a 1,000 mile roadtrip this weekend. I am assuming the code kept popping up due to a small exhaust leak I had. But once I welded it up all was good and the car was nice and quiet again.
Next on my to-do list are front right motor mount (mine is completely shot), timing belt, oil change within the next month or so, and maybe switch to some oil filled shocks..the roads here are too rough for the ones I have now
maybe get some new tires installed sometime in the winter and then just enjoy it from there on out. I still have to do the glove test and make sure the PCV isn't clogged.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
Rear trailing arm bushing/bushing assembly , struts/springs(good idea but not mandatory), LCA's w/ball joints, wheel bearings, links, strut mounts/bearings and all hardware if u can get factory/factory quality or better. When choosing struts I would choose by quality not price...I ordered the front struts from FCPgroton as a kit that came w/everything to re-assemble the front struts(sachs struts-there the OE brand). When I got around to doing the rears I wanted to do them while I was doing something else and made the mistake of buying Monroe rear struts because they didn't have the Sachs/Bilsteins or KYB's. I'm planning on ordering the Sachs from FCP and I'm going to return the Monroe's cause they suck!!koffinb wrote:What are some of the most common weak suspension points on these cars? Looking at the records I don't see much in terms of suspension work apart from sway bar links, a control arm and delta anchorage links (whatever those are)
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
What don't you like about the Monroe's?shiloh51933 wrote:Rear trailing arm bushing/bushing assembly , struts/springs(good idea but not mandatory), LCA's w/ball joints, wheel bearings, links, strut mounts/bearings and all hardware if u can get factory/factory quality or better. When choosing struts I would choose by quality not price...I ordered the front struts from FCPgroton as a kit that came w/everything to re-assemble the front struts(sachs struts-there the OE brand). When I got around to doing the rears I wanted to do them while I was doing something else and made the mistake of buying Monroe rear struts because they didn't have the Sachs/Bilsteins or KYB's. I'm planning on ordering the Sachs from FCP and I'm going to return the Monroe's cause they suck!!koffinb wrote:What are some of the most common weak suspension points on these cars? Looking at the records I don't see much in terms of suspension work apart from sway bar links, a control arm and delta anchorage links (whatever those are)
- Has thanked: 292 times
- Been thanked: 765 times
When I bought my current NA wagon, it came with new Monroes up front. Pretty squishy ride, like being in a boat. I swapped them out for Bilstein TCs, much more what I was looking for (improved front end control in turns, without tooth rattling over bumpy roads). The Monroes are sitting idle out back on a slowly fading parts car.
Note however that I have also heard of people with stiffer springs (like the ones that come stock on an R), longtime owners even, who love the Monroes as a cheap solution on those setups.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Nice R in "arrest me" red. Replace both o2 sensors if no evidence of prior replacement. They are a maintenance item at 100K miles. Failure to replace may lead to eventual burned exhaust valve. It is cheap insurance to replace them and as a bonus, you might notice a small improvement in fuel economy.
At that mileage, your entire suspension is pretty much due for a refresh, although you could get away with putting it off for a bit depending on budget constraints. Once you start to hear and feel klonking from the front end, you should address the suspension. You might go to 150k or even as high as 180, but the handling is likely to be pretty compromised at 180K with no suspension work.
Best not to piecemeal the suspension. Once you're in there, replace as much as possible since the components wear in together and it is a pita to bolt up and unbolt all that stuff repeatedly.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- shiloh51933
The ride quality seems kinda sloppy/different than previously w/original struts, shoulda left the oem struts in till I could get what I wanted(Sachs). I was replacing R/R trailing arm bushing and wanted to do the rear struts/strut mounts while I had it in the air and then do the wheel alignment while I had it w/me @ work. I should have ordered from fcp and waited but the alignment was off bad, so I went ahead buying struts locally(mistake).koffinb wrote:What don't you like about the Monroe's?shiloh51933 wrote:Rear trailing arm bushing/bushing assembly , struts/springs(good idea but not mandatory), LCA's w/ball joints, wheel bearings, links, strut mounts/bearings and all hardware if u can get factory/factory quality or better. When choosing struts I would choose by quality not price...I ordered the front struts from FCPgroton as a kit that came w/everything to re-assemble the front struts(sachs struts-there the OE brand). When I got around to doing the rears I wanted to do them while I was doing something else and made the mistake of buying Monroe rear struts because they didn't have the Sachs/Bilsteins or KYB's. I'm planning on ordering the Sachs from FCP and I'm going to return the Monroe's cause they suck!!koffinb wrote:What are some of the most common weak suspension points on these cars? Looking at the records I don't see much in terms of suspension work apart from sway bar links, a control arm and delta anchorage links (whatever those are)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
European guys like to think Meyle struts are of comparable quality with the Sachs
http://www.ebay.com/itm/MEYLE-Left-Righ ... 85&vxp=mtr
Control (trailing) arms are a weak point at 60k miles. Replacement bushings don't last - except the polyurethane ones, and are very hard to fit. The control arms cost an arm & a leg at the dealer. Yet, when they are worn, the handling is terrible.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I actually like doing suspension work, it's all nuts and bolts.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
Matty Moo wrote:I actually like doing suspension work, it's all nuts and bolts.
...and those big gnarly springs
- 1745 Views
- 1953 Views
Last post by SuperHerman
