1999 V70 Ridiculously Rounded Drain Plug Advice
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 8 times
Post by deepsouth »
Same car I've got the head pulled on. Went to drain the oil and this is what I found the drain plug looked like. I have a killer set of Irwin Bolt extractors and they simply tear into the soft metal and spin off (even when going down a size and hammering it on). It doesn't help that the upper left corner is missing a chunk. I'm at my wits end--this thing will not freaking budge. Any ideas?
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I've always had luck with bolt out sockets, are they slipping?
If so: Try filling two flat edges and then use wrench. Before that try some vise grips.
To be honest: I've always found the bolt outs the best solution, hammer on the ratchet with rubber mallet
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
deepsouth
Post by deepsouth »
Yeah, because of the chunk missing from the upper right they are slipping off (until now, they've never failed me either). So far, no luck with vice grips either. This thing feels like it's been JB Welded into place. :evil:
2001 XC70, 129,000
Been thanked: 472 times
Post by cn90 »
Is there room for pipe wrench?
dosbricks
Post by dosbricks »
Chanellock nut buster (also know as parrot jaw). I've had a set for 40 years and never failed me yet. The more torque applied, the tighter they grip, and they don't care what shape the bolt/nut is.
https://www.channellock.com/product.aspx?zpid=358
timmybdaddyof3
Year and Model: 1998 V70 T5
Post by timmybdaddyof3 »
+1 to the channellocks, another thought is to take a dremel to two sides of it so you have something to lock a vise grip on. Another thought is to drill a small pilot hole in it then hit that with an easy out bit
Oh yeah, when you get it out i would buy a new plug ;)
Has thanked: 1505 times
Been thanked: 3818 times
Tack weld a rod to it. Make sure you can clear the total 360 rotation.
You can then re-use that plug, too. Not.
rmmagow
Year and Model: V70 1998
Post by rmmagow »
The channellocks have worked for me in a similar situation with a rearend drain. I have also used an electric impact with the bolt removal thing in the past on badly rounded plugs like this. If you weld, be sure the battery is disconnected.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Pipe wrench.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
+1 to the pipe wrench - awesome method, but... it only works when torque is applied in the right direction (please don't ask me how I came to know) :shock:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
