1996 850 GLT Code P0304
olfac87
Year and Model: 850 GLT 1996
Post by olfac87 »
The check engine light came on today. Local parts store checked the code and it is P0304. Internet research says a misfire. I replaced the plugs one year ago, I believe with Volvo plugs (need to check as I didn't write it down). Does 0304 mean cylinder #4? (My insinuation from reading other posts.) I just recently cleared code p0422 by replacing the cat (2 months ago). And I installed a new fuel filter about a month ago.
I have no history of my replacing the cap, rotor or plug wires in the last 80k+ miles. (Car now has 134k.)
Not sure where to start with the troubleshooting - any suggestions would be great.
07 V70R 6 speed || 96 850 GLT 5 speed
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Did you use Volvo plugs? Run a compression test or just do a full plugs, wires (Bougicord) Cap and rotor (Bosch). And ONLY Volvo plugs.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
olfac87
Post by olfac87 »
rmmagow - I need to pull a plug to see what I used. I currently have Bougicord wires on and a Bosch rotor. Can't tell how old and am looking through my records to see if I missed recording any replacements on my master service history list. For a compression test, I assume that requires special equipment or a mechanic? (I am a novice car tinkerer.)
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
olfac87
Post by olfac87 »
That was a really helpful video. Looks like a series of tests I can do at home. Thanks for posting it.
olfac87
Post by olfac87 »
rmmagow wrote:Did you use Volvo plugs? Run a compression test or just do a full plugs, wires (Bougicord) Cap and rotor (Bosch). And ONLY Volvo plugs.
I finally worked on the car today. The old plugs were Bosch Platinum. Even though they were 1 year/7k miles old, I replaced them with Volvo plugs along with a new Bosch distributor and rotor, Bougicord plug wires and Mann air filter. The car works so far. The check engine light is still on - I presume I need to reset it with the code reader?
Has thanked: 292 times
Been thanked: 765 times
Other people have had issues with those Bosch platinum plugs, that could have been why #4 misfired. Regardless, those new ignition components will work great. If something does pop up you will know not to blame them.
Yes you have it, the CEL must be reset. You can also unhook the battery if you want to, that is another (a bit more dramatic) way to clear the codes.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
