Help, I was changing the electrical portion of my ignition switch (ABS light problem) per Robert's video and the switch I pulled at the junkyard today came off easy. Of course mine didn't want to, and the wire connectors separated from the plastic alignment guide The manual I have only lists the key positions and shows one trace. Can anyone direct me to, or PM me a pin-out chart or schematic for the ignition switch?
Thanks
Patrick
Current Volvos:
Thank you sir, a thing of beauty, pin numbers and colors!
Now to put it back together
Patrick
Current Volvos:
Thanks again Lee all together and works good.
Note: for terminal 50 my car doesn't have the Green/Red wire, it's Yellow/White. All others as listed.
Current Volvos:
