I just learnt about the ECU relearn !
Locked
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Raul's posts and members' replies about Does a 2011 S40 Have a Radio Code moved into that topic.
Also -> Amazon link
Reinie
Year and Model: 1999 S70
Post by Reinie »
Here's my interpretation of a proper reset for my 2005 V50 T5. 1.) disconnect battery 2.) discharge current from the system by touching the battery cables together for 10min OR leave the positive cable on the battery with the negative cable disconnected, then step on the brake pedal. All current is now discharged from the system. 3.) turn the ignition ON to position II. 4.) first, connect the positive cable to the battery (if not already connected) 4.) next, connect the negative cable to the battery. Here is my question with the car now energized. Should the ignition be turned off? Or should the car be started from position II and driven through the relearn sequence?
Ben850
Been thanked: 7 times
Post by Ben850 »
The interesting thing that I have found in regards to my T-5R is the fact that an aftermarket Viper alarm unit was installed. It was in an accident, and the air bags were deployed.
As a result, I have a need to dis-connect the battery each time I park.
The SRS sensor, and air bags, seat belts... all need replacement.
( In another thread I will discuss SRS parts as to not confuse this subject).
My point being, this car starts anew each time I fire it up. The ECU learns quickly within short drives.
When I say "short" I literally mean, around the block, and to a different spot at the house. All the while though, I will let it warm to 3 o'clock before I move it.
Continue having fun.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Friday131984
Year and Model: 1999 s70 glt turbo
Post by Friday131984 »
Ok guy I just bought a 2000 volvo s70 se. Got it home it runs like crap checked the obd2 diagnosis reader and found that I have a p1608 which is emc malfunction, a p1670 electronic feedback signal not detected a p1611 which is a key if discord imm-emc a p1611 chain of ecm-immu and a p1613 mil request signal circuit high. 4 out of 5 codes state that it has a faulty ecm so do I do a reset on ecm or change ecm completly?
Been thanked: 4065 times
Well the reset is free and the ECU swap may involve both software and VIDA at dealer to marry up - so I would try the cheap thing first!
mzkeia
Year and Model: 2009 s80
Post by mzkeia »
I am trying to fix whatever I broke. I removed fuses and now I have no control of my wipers and blinkers... I cant do anything to the dash
PLEASE HELP!!!
Locked topic due to chaff
Locked
