Hi guys,
I just got polly bushings for my torque rod and firewall mount. When trying to press the old rubber one out the entire sleeve that I think was welded to the torque rod came off. I can't for the life of me get the old bushing out. I can post pictures to better explain if needed.
I have access to a welder and am just wondering if it's a terrible idea to weld it back on or if I should buy a new assembly. They're pricy so id rather not. Thoughts?
97 850 upper torque rod bushing
dairyqueen814
- Year and Model: 1997 855 NA
1994 850 Sedan NA Black, 343,000mi - Crashed and parted
1993 850 Sedan NA Red, 240,000mi - Now my little brother's car
1994 850 Wagon NA White, 251,222mi - Sold
1997 850 Wagon NA Red, 105,000mi - Currently my pride and joy
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
This may help a little https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=49330
- Been thanked: 504 times
Weld the ring back.
Then put in new bushing, I recommend Lemforder, about $10:
https://www.matthewsvolvosite.com/forums ... hp?t=53200
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Page 4 shows the tool I made, it was still tricky so on my 850 I used a poly mount.
Slightly more vibration at idle but my wife didn't notice any difference.
https://www.matthewsvolvosite.com/forums ... e&start=42
I used this part from Pelican Parts. Installed like a charm and looks to be high quality
- Pelican parts
- image.jpg (175.02 KiB) Viewed 798 times
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
dairyqueen814
Alright cool
Thanks guys
while I had the bushing out I decided to do a quick check and had my mother step on the gas and brake while I watched the engine and It was definitely moving more than it should be with no upper mount. When I do the tranny swap in a week or so I think I'd like to replace all the mounts
Is there 3 or 4?
theres one that bolts on to the tranny
one under the t-belt
and one? or two? in the front?
also what brand would you recomend? The Volvo OE ones are like twice the price of some of the others (and I'm guessing for good reason) Is it worth the extra money?
Thanks
Nick
Thanks guys
Is there 3 or 4?
Thanks
Nick
mecheng
Inspect each one, if there are no tears then all is well. Lemforder / or Corteco is OEM and cheaper than the dealer part. Pelican Parts list who is the OEM supplier
Look at 2 places:
- rmeuropean dot com
- Volvo dealer websites (many dealers sell parts on the web)
Then compare prices between Volvo OEM vs:
- Hutchinson
- Lemforder
- Corteco
The "other brands", search forum and you will know why I only mention the 3 names above.
- Hutchinson
- Lemforder
- Corteco
tryingbe
- Year and Model: None
- Been thanked: 26 times
dairyqueen814 wrote: also what brand would you recomend? The Volvo OE ones are like twice the price of some of the others
Bushing
(9434288) $16.52
http://www.jimellisvolvoparts.com/showA ... gory=24175
I'm going back to OEM mounts from poly bushings, I don't want the vibration anymore.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
dairyqueen814
I threw it in our wood stove and burned the rubber out then pushed the rest out with a vice and a big socket set
welded the bushing sleeve back on to the mount and its all good to go
on the drive home i noticed a LOT of vibration and some of my lower mounts were looking pretty rough
I think those are next on the list
Thanks guys
Thanks guys
- 13 Replies
- 3645 Views
Last post by theWIFES_S70
- 867 Views
Last post by lext
- 713 Views
Last post by 454cid
- 678 Views
Last post by MoVolvos
- 768 Views
Last post by MadeInJapan
