1993 850 Driver Window Console Switch "Fix"?
Ben850
Been thanked: 7 times
Re: 1993 850 Driver Window Console Switch "Fix"?
Post by Ben850 »
Paul-93-850 wrote:The local junkyard has no Volvo's currently and the ones on eBay are not tested. If my mod works I'll save money. If it doesn't then I'll have to cut the wires going into the motor and apply power from the battery to test it. If it's the motor and not the window being jammed up, then it will use the motor from the LR door.
Do you think auto parts cleaner or lime-away would clean contacts bare? I have cleaned my washing machine tub of all mineral build-ups and the same with toilet. Yeah, I fix everything as necessary.
I can not give you a definitive answer.
Continue in a positive direction.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Paul-93-850
Year and Model: 1993 850 non-turbo
Post by Paul-93-850 »
Success! Driver Window works again!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Glad it worked out for you. ;)
