Thought I had the information, believed I saw it on MVS.
How can I tell other than the engine # which valve stems I have
Thanks
James
2000 s80 stem seals 7 or 8 mm
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
jimmy57
- Been thanked: 320 times
Volvo Engine Valve Stem Oil Seal - Genuine Volvo 3517893OE
Available
Position: N/A, Part: Engine Valve Stem Oil Seal, To Engine 1818168
$6.95 +
Volvo Engine Valve Stem Oil Seal - Genuine Volvo 9443787OE
Available
Position: N/A, Part: Engine Valve Stem Oil Seal, From Engine 1818169
$6.95 +
Find your engine number and refer to the numbers above. 7mm stem is the lower range and 6mm stem is the higher number range.
The number will be on the timing belt cover if the label is still there.
Available
$6.95 +
Available
$6.95 +
No numbers on cover, can one check a number on the vin or something somewhere else
I thought I remembered something about production dates
Thanks
Thanks
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
so one needs the vin it seems
no other way to tell?
What differences are there on the engine, they are both vvt
are the 8mm valves sodium filled and stronger, or heavier or both
which is better?
thanks
which is better?
thanks
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
I also am looking at timing belt water pump combo kits, the ebayer is selling them and will fit all the whiteblocks. Guess this is true.
Don't really care to skimp on water pumps and timing belts. What is the recommended?
Thanks
p.s noted in the video, behind timing cover. on left side. perfect!
Thanks
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
