98. V70. Started, idle good, 1500rpm max
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
I'm sitting in my car , idles fine, step on the accelerator maxes out at 1500 rpm. What's up? Oh the high today was 3 but this am at 0430 it was minus 8.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Been thanked: 4063 times
Throttle body or linkage frozen perhaps
stephansvolvo
I remember reading in a thread somewhere on MVS that turbos no like cold. It took about 5ish minutes but it warmed up and ran like a champ.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had symptoms like this a few years back up in Connecticut during one winter after a prolonged deep cold spell. In my case the solution was to apply low heat from a hair dryer on the metal fuel filter body. Longer term during the winter seasons I started adding ~0.25 liter of isopropanol dry gas to the fuel tank to absorb the water and keep it from freezing and plugging up the fuel filter.
If you have water in your fuel 0F will bring that issue up. Unfortunately adding dry gas to a frozen fuel system won't cure it until it warms up
Veteran of many Ithaca NY -30F spells
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Your intercooler or turbo pipes probably froze over. Next time it's above freezing outside, take some Cascade dishwasher detergent and rinse the intercooler out with a hose.
'98 S70 T5
2016 Chevy Cruze Premier
stephansvolvo
Thanks for the input guys. I'll give it all a go.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- 984 Views
Last post by nameuser
- 3335 Views
Last post by oragex
- 14 Replies
- 4358 Views
Last post by johnrapier
- 11 Replies
- 4591 Views
Last post by dim28
- 696 Views
Last post by ricsamdan1
