1986 240 DL Prioritizing repairs
mhgreen
Year and Model: 240 DL 1986
Post by mhgreen »
Can I advertise my need on the forums? I know that many Volvo owners have stuff laying around. I am asking if it is appropriate, as I am new to the site.
“Some cannot loosen their own chains and can nonetheless redeem their friends.”
mhgreen
Post by mhgreen »
Moreover, I just realized that the AMM is not OE. The brand is Fuel Injection Corporation. Thus, if I am going to install OE (used), how would I go about pinpointing which part number I need?
rgk
Year and Model: Gray 88 245
Post by rgk »
Matt's Volvo forum has a board especially for that. It's called Classifieds - Parts.
Just go to eBay or your favorite auto parts store website, type in your year, make and model, and you will see which parts are available for it.
rgk -- was dickdeadly
rgk
Post by rgk »
On eBay, for example, type '86 Volvo 240 OEM MAF'. Just be careful: non-OEM parts WILL show up in the results.
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
Register on Turbobricks and post a wanted ad there ("Wanted" section under "Classifieds" section). You will likely get a response in less than an hour, with a good used AMM at a great price. Be sure to post the last three digits of the AMM in the wanted ad ("016", "007", "002", or whatever it is). You have LH2.2 fuel injection, I believe.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
mhgreen
Post by mhgreen »
Found an AMM/MAF on Turbobricks classified forum. Thank you for pointing me in that direction.
mhgreen
Post by mhgreen »
Update:
- radiator hoses replaced (coolant drained and filled)
- spark plug wires replaced
- purchased OEM AMM on turbobricks, will install once it arrives
- had transmission leak from cross-threaded pan bolt after transmission drain and fill by the incompetent technicians at a massive chain quick-lube (I will never go there again). Local tranny shop replaced pan, gasket, flushed transmission fluid - - the quick-lube will be reimbursing me.
- oil change is right around the corner… Any advice? Type of oil? I have Lucas oil stabilizer that I would like to add as well.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
These cars have a transmission pan drain plug for a reason.
1988 Volvo 760 Turbo Wagon
mhgreen
Post by mhgreen »
Update:
- Brake junction block replaced
- Replaced aftermarket, bad AMM with Bosch OE *** car starts much better in the morning. Doesn't struggle
Now I want to replace the temperature sensor but I would prefer to leave the intake manifold in place. Any thoughts on doing this? I assume the flame trap will be a b**** to maneuver around. Any suggestions would be appreciated for this project. Thanks again everyone.
mtd240
Post by mtd240 »
Nice you're making progress.
For the temperature sensor, I use a 3/8 ratchet and an assortment of wobble extensions with a u-joint adapter, and a deep socket (17 or 19, I think?). Facing the intake manifold, youwill have to reach one hand under the left side to guide the mish-mash socket assembly directly onto the sensor from the right.
Confusing, but it can be done.
Gone:
