2002 S40 auto Volvo, seeking help / advice. My right side low beam light does not work. I have replaced the bulb (also tried a Volvo bulb), that was not the case. Checked ALL fuses under hood and inside the car 'all' fine. Does anyone out there have any friendly advice? Please
Also, I am in need of a Right side windshield wiper arm. If anyone has a used one for sale, please reply.
Thank you!!
2002 s40 right windshield wiper arm & 'r' low beam light out
Dear AI-31904,
You need to post this in the S40, V40, V50 Forum to get a reply on the low beam light problem. I'm having the same problem and was hoping you would get an answer but just realized you won't unless you post it to the forum instead of the parts section.
Cindy
Cindy
- Has thanked: 2855 times
- Been thanked: 1332 times
moved
shanegtr
- Year and Model: 1999 V40 2.0T
Problem will most likely be a stuffed relay in the CEM. Needs either a replacement CEM or if your handy with the soldering iron then you can easily desolder and solder in a new relay (I'd do both the headlight relays)
Theres a dam good write up here:
http://www.volvoforums.org.uk/showthread.php?t=67584
