1986 240 DL Prioritizing repairs
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lummert
Year and Model: 760 1988
Been thanked: 26 times
Re: 1986 240 DL Prioritizing repairs
Post by lummert »
22 mm = 0.86614"
7/8" = 0.875"
0.875" = 22.225 mm.
Are you still confused. The difference is .225 mm.
1988 Volvo 760 Turbo Wagon
mhgreen
Year and Model: 240 DL 1986
Post by mhgreen »
Haha no I realized after i posted that the idiocy
“Some cannot loosen their own chains and can nonetheless redeem their friends.”
mhgreen
Post by mhgreen »
Trying to replace sensor - - 7/8 deep socket is not deep enough to reach hex. Any suggestions?
mhgreen
Post by mhgreen »
UPDATE:
- oxygen sensor replaced
Initially was concerned because I cut the wires and yet could not fit the deep socket on the hex ... met up with a guy here in Portland that I know from 'turbo bricks.com' and he helped me out. Drivability has improved since replacement.
mhgreen
Post by mhgreen »
UPDATE:
- coolant temperature sensor replaced
- fuel filter replaced
mhgreen
Post by mhgreen »
What I have done up to now:
- Fuel filter
- Fuel injection temperature sensor
- Coolant temperature sensor
- Radiator hoses, drained/replaced coolant
- Air mass meter
- Cleaned Throttle body
- Air filter
- Oxygen sensor
- Transmission oil flush
- New tires
- Valve cover gasket, camshaft seal, flame trap
- Replaced all fuses
- Spark plugs, wires, cap, rotor
- Timing belt
- Brake pads
- Brake junction block
- Cleaned IAC
Next up….
- oil change : I am planning on using 15w-40. Any thoughts? I also elected not to use any oil additives after doing some research
- Rear trailing arm bushings : a local shop will do them for $140, but I have a turbo bricks contact that might be willing to do them for some beer
Anything I am missing? Any suggestions on jobs I might have overlooked?
mhgreen
Post by mhgreen »
UPDATE:
I went ahead and had the local volvo shop replace the rear trailing arm bushings. The bushings that were in there were original (28 years old), and they looked as if they had been through the underside of a lawnmower. Anyways, the car feels very different - - much better overall
- rear trailing arm bushings
- shift linkage bushing
- replaced alternator, power steering, a/c belts
rgk
Year and Model: Gray 88 245
Post by rgk »
8)
rgk -- was dickdeadly
