Anyway, I just wanted to report that the entire job took about 3 hours.
To install the amp I unbolted the seat but just lifted it up and moved it back to give me some room to work. I DID NOT unplug any of the wiring to the seat. Installation of the amp is easy and just requires two flange screws. I went ahead and ordered 2 985186 for about $2.63 each locally from the stealer. I removed the center console. I'm not sure if I needed to but it probably did make the job easier even if it was not required. The carpet under the seat has three pre-cut holes. Just three of the four sides of a square are cut so there is a flap that can be folded out of the way when needed. The two smaller ones are for the amp mounting bracket and the larger one is for the wiring harness. The two smaller ones were hard to find, they are under where the inner seat rail would be. I simply ran the amp end of the harness under the carpet, through the larger hole in the carpet, connected to the amp and mounted the amp. Next, run the cable along the hump, outside of the center console but under the carpet. There are two holes here for the flat plastic part of the harness to snap into. Since mine was used, it was pretty obvious where it went, the wires had a memory and just sort of layed where they were supposed to go. The two plastic clips mentioned above and one other even matched up to holes in the car so it looks like the car came with the harness, my favorite kind of upgrade! To get the radio and car end of the harness up behind the radio, remove the old radio and just reach up behind the radio cavity from beside and above the hump, kinda' from under the glove box / mapholder area. Reach through the radio opening with the other hand and you can easily feed the harness through to your other hand into the radio cavity.
The connections are obvious, the amp end can only go one way (to the amp), the car end is basically, to the car speakers and the radio end, well, if you can't figure it out, maybe you should seek help with this upgrade
I did find that it was a little bit harder to get the SC-901 all the way into the radio cavity than the SC-816. I am not sure if this is because the 901 is a bit deeper, or maybe I didn't quite get all the new harness plugs out of the way. I tried my best to move all the excess cables and connectors out of the way and the radio just barely goes in far enough to close the clips on the side of the radio.
I have an iPod connector in the CD port so this works on CD6. Maybe this plug was interfering with pushing the radio all the way back but it was there with the 816 as well.
Anyway, the upgrade is complete and yes, it does sound way better than the 816 with no amp and I'm sure after reading the Rothe info, it is better than if I had bothered to try the 816 with an amp. It sounds great!
I am off to customize the EQ settings now...
