2000 S70 - Headlight update/upgrade?
This topic is in the MVS Volvo Repair Database » Upgrade Headlights - What to Buy
neworleans
Year and Model: 2007 S60R
Post by neworleans »
Hello all,
As you all know the headlights on our S70's get old and don't light as it is supposed to at night drive.
My high beams are like low beams and low beams are like fog lights. Very weak.
Looking at these headlight lenses, if I replace them how much difference would it make? Has anyone tried it? I was also looking at the HID upgrade but of course it costs bunch of money.
What would be your thoughts on this?
https://www.fcpeuro.com/products/volvo- ... 70ecodekit
mathieu_p
Year and Model: 1997 S70R
Post by mathieu_p »
Did you try brighter bulbs?
I exchanged my headlightbulbs to Philips diamondvision and I am satisfied with that.
Idea for you?
Volvo for Life 340/440/480/S40/S70R/XC90 V8 next?
Born and raised in Holland, lives where Heineken is brewed.
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
I just put in Depo jewel headlights (for 2003-2004 C70) in my 1998 V70 last night. The difference is dramatic. It is a simple swap - 6 bolts - and they are in. I am waiting for the matching corner lamps to be delivered, but I think they look great. I bought them on Amazon for about $240 (corners were another $150).
The old headlights had the swapped lenses and they looked okay, but not nearly as bright as the jewels.
Has thanked: 311 times
Been thanked: 817 times
I have used e-code lenses. There is only a small difference vs. standard, if both are relatively clear (non-pitted) glass.
neworleans
Mathieu,
I've tried the sylvania's bulbs which helped little bit but they have a short life.
Never tried Philips diamondvision.
Seaway, I thought about replacing them with the C70 headlights but like you said with the corners it costs 400 bucks. The other option is to replace with the projector headlights which also costs around the same. I wasn't into spending that much money for the headlights so I came across with these lenses.
Did you consider the projector headlights before putting in the C70 headlights?
Seaway
Post by Seaway »
neworleans wrote:Mathieu,
I considered the projectors, but I don't really care for how they look. I think they look good on some cars, but overdone on others. That said, the lights I just put on are much more flashy than the old ones, but I like the look. Without the matching corners it looks kind of half done or I would have skipped that part. My old lights had new lenses and they weren't bad, but they don't put out as much light as the jewels.
neworleans
I totally agree, these look a lot better than projectors ones.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Do these lights have the vertical and horizontal adjustment screws?
Seaway
Post by Seaway »
kahl wrote:Do these lights have the vertical and horizontal adjustment screws?
They do, yes. The Depo lights I got do not have the level built in, however.
kahl
Post by kahl »
thanks Seaway. FWIIW the level is removable.
