sibir wrote:I had the same problem: Changing the volume created a nasty crackling sound and even drop outs in the right channel. So I pulled out the radio (push in the 2 vertical "bars" on the lower left and right of the faceplate, handles will pop out, then just pull) and removed the top cover (couple of screws).
Look inside and you see the potentiometer.
It has little openings through which you can see the slider move when you turn the knob. The crackle is caused by dirt under the slider. That's where you should try to clean.
I successfully used tweezers with a little piece of strong paper soaked with IPA (alcohol). (Just squirting IPA in there and moving the slider did not do much.)
suspensionbrakesbmwwheels
I slid in the paper under the slider and was able to remove some dirt. I repeated this until the paper looked clean. But be carefull not to damage the slider. If it breaks you need a new potentiometer at which point you might look for a replacemnet radio as well.
Good luck!
crackling radio volume switch Topic is solved
Volvo 850 Instrument Cluster Bulbs
Thanks for posting this, it helped me out.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
You're right, and it is now in the repair database. I actually need to do something similar to my early 80's home stereo that has the exact same problem. Thanks for this contributionIs this stickied? Should be.
GREAT post !!!
'98 S70 T5
2016 Chevy Cruze Premier
Medusalith
- Year and Model: 440Glt1.7'94/V40 1.6
I have a TD-603 Alpine i my 440glt/94 and it started to do that crackling sound once a radio station is recived in stereo mode, the volume also seems to have lost some volume potency, did that happen in your cases also or does my tuner deck may be in need a diffent fix?
- hanzbe420
- Year and Model: 2006 s60 2.5T
Good luck!
or you can use a can of this stuff
Or you can use a small spray of wd40 now this might mess up your radio by making it sticky after time, but i used wd40 and it fixed it just fine now as for the long term effects of the wd40 i dunno lol but it doesnt matter i have 2 extra head units. But its best to use some "Deoxit". Just offering some alternative methods for people without the proper items or just not enough time.yea i forgot to mention turning the knob fast back and fourth 15-20 times then dab a napkin on around and try to slide a Lil underneath before you spray to avoid getting it elsewhere.
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
sometimes a couple of dollops of contact cleaner while excercizing the knob/pot is enough to do the trick.
shonamc1997
- Year and Model: 850 1994
Thankyou so much! This worked perfectly for me, i used reading glasses solution instead of alcohol and it still did the trick.sibir wrote:I had the same problem: Changing the volume created a nasty crackling sound and even drop outs in the right channel. So I pulled out the radio (push in the 2 vertical "bars" on the lower left and right of the faceplate, handles will pop out, then just pull) and removed the top cover (couple of screws).
Good luck!
Hi, can you tell me where you sprayed as in my unit it’s just a blue switch on top of the PCB?t5rrr wrote: 06 Dec 2009, 18:39 Did this fix today, sprayed contact cleaner in the sliders and a sliver of paper and rotated full range about 10 times, no more crackling!
Thanks for the tip!
- 1131 Views
Last post by bobc997615
- 2267 Views
Last post by mrbrian200
- 1803 Views
Last post by dahammer
- 689 Views
Last post by wole1
- 1059 Views
Last post by wizechatmgr
