95 850 Battery/Starting Issue
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
UpsnDowns wrote: tryingbe - the meter was connected to the battery post. How can that be the alternator voltage?
Because the meter will only shows the higher voltage. You need to measure the battery when the car is NOT running.
Did you check to see if the glove box light is on at all time?
85 GLH, 367 whp
00 Insight, 72 mpg
UpsnDowns
Year and Model: 850 1995
Post by UpsnDowns »
"Did you check to see if the glove box light is on at all time?" Yes
