No fuel revisited ! 91 940 Turbo Wgn
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
zoomduck
Year and Model:
Post by zoomduck »
New relay , fuses good , pulled fuel pump from tank and connected it to the battery . Fuel pump runs . No power from wire harness that connects to the pump . Starts for a second then dies . I am at a loss . :cry:
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If there is no power at the harness with the ignition 'on' and fuse #11 intact there must be a break in the wiring somewhere between the ignition switch and the end of the harness.
If you have a multi-meter check for 12v, with ignition 'on', at the battery side of fuse #11. Even though you have checked the fuse check for 12v at the pump side of fuse #11. I have had a break in the fuse box before.
If have 12v at both places then I would suggest running a new wire from the fuse box to the pump. This is not too hard to do if you follow the harness and tape the wire to the harness.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
