1995 850 Converting to awd
This topic is in the MVS Volvo Repair Database » 850 AWD DIY Conversion?
Has thanked: 311 times
Been thanked: 817 times
I don't have an AWD but yes, the top of the FPR gets vacuum lines, that is how fuel pressure is regulated under boost vs at idle. So they will go to the engine bay but I don't know where.
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
GREAT idea. I thought about doing the same thing.
Go to this website:
http://www.volvopartswebstore.com/
Key in the info from your donor car and then you can pull up a diagram for the fuel line, transfer case, etc. If you have a good printer you can blow it up on 11 x 17 paper. Good luck.
JonVal
Year and Model: 850 t5 1995
Post by JonVal »
thanks Shaker_chi
I found this , in an old volvo book i have :) but thank you for the link , it is saved
shaker_chi
No problem. When you go to that link you will see some pretty good diagrams with part numbers as well in case you have to order anything. I use it all the time.
JonVal
Post by JonVal »
Hi
Any one know if this is correct , installing m58 gearbox with angelgear, 98 mod . The old gearbox m56 had speed sensor in the gearbox. But that was changed in 1996 i belive when the obd2 came. As I can figure out , they pick up speedo signal from one of the abs sensors...
Place a jumper between Brown / yellow cable on connection . No. 33 (red socket) and Green / red cable connection . No. 24 ( white base) on the left side the steering column under the dashboard
Anyone had this problem ??
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
You should be able to tap a wheel sensor to get the speedometer signal. I'm at my cabin so I don't have the schematics with to give you wire colors. The wheel sensor and the transmission sensor have the same number of pulses per revolution.
JonVal
Post by JonVal »
Thanks , Lee
Jon
JonVal
Post by JonVal »
Hi
Anyone know the difference between red and yellow sway bar, rear suspension , 1998 mod awd , b5234t4 ?
Volvo dealer here can t make up his mind :roll:
Jon
