1999 S70 Timing Belt Needed?
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Post by volvooh »
I am looking at another S70- Its a '99 with about 130,000. Last timing belt change was in 2008 with @ 57,000 mi. Can I get another 25,000 mi or do I need to do a timing belt/ pump change now if I purchase. This will be a daily driving for a 16 year old, mostly to and from school (about 2 mi).
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I believe the book service interval got bumped to 100k miles starting in '99 but personally I still follow the old 70k rule since a failure is so catastrophic. My wife had a Chrylser Concorde years ago that had a 100k interval and it ate a water pump and took out the belt at 101,870. Fortunately that was the version of the engine that was not an interference engine. All of the Volvo 5 cylinder engines are interference engines.
I guess the short answer is that you probably can get by with it but if the car gets driven hard you might not.
volvooh
Post by volvooh »
So is it an issue of miles (70,000 to 100,000) only or is there a time limit (say 10 years) that the belt should be changed as well?
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Yes, there is a time limit also. It is 70k (or 100k) or 10 years, whichever occurs first.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1500 times
Been thanked: 3810 times
105k for the 1999 on. Drive it, be happy.
2 mile trips are brutal on PCV. Use synthetically oil and change every 5000 minimum, or try to get the car up to 55 for 30 minutes at least once a week. Thank goodness you have the heated PCV on your 1999, if you are a really good person God will bless you with a turbo and a manual, too.
volvooh
Post by volvooh »
Abscate- thanks for the head's up. I agree with everything but the manual transmission...don't want to have to teach a 16 year old to drive a stick...especially on a 15 year old car! I'll be replacing the clutch by the end of the year!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I wouldn't give it more than 10,000 more miles. There may be a higher limit on 1999 and newer, but I would be worried about it snapping. You could probably get more out of it, but that's one of those repairs that you shouldn't push out as long as you can.
Mccjim12
Year and Model: 1999 S70
Has thanked: 2 times
Post by Mccjim12 »
Old as hell thread but I was digging around as I just had my ‘99 S70’s timing belt, serp belt and all the associated components changed.
I bought the car in ‘19 with 135k miles. Had receipt for TB at 108k…in 2010. Car was off the road from 2015 to 2019. She now has 183k.
So almost 15 years since last change. I am grateful that it hung in there that long. I don’t know what kind of shape the belt was in but had I been more knowledgeable at the time or purchase I probably would have addressed it sooner.
Anyone have any stories good or bad going past the time or mileage intervals? This is getting to be an old car but I love it and hope to get another little while out of it now.
Thanks!
Jim
Has thanked: 1836 times
Been thanked: 1709 times
Going past the interval seldom ends with owners being happy! Many older Volvos end up in the junkyard and have broken timing belts.
I ran my T5 to 14 years/140k miles before replacement. I did the next one at a valve job at 256k.
The p2 has the same interval , but if you use the same parts in a PZEVstate, they are warranteed for 15 years/150k miles.
Risk aversion is a personal thing, but there is good evidence that the MTBF is well past 150k miles
Rubber belt…fails on time and miles, especially in ozone states
Idler and tensioner fail on miles, weak association with time
Don’t forget water pump at second belt change, so anything over 150k, do the p80 pump too. I ran mine to 250k, too
